Outdoor frame of 11 gauge steel tubing
发表于 2021-8-31 22:34:29 | 显示全部楼层 |阅读模式
I'm planning on making a table of rectangular tube for use outdoors.  All the tube will be welded and end capped so in theory the inside is sealed from the weather.  Do you think a few weep holes on the bottom of the assembly is a good idea or not?
Reply:good idea.  Better idea is to leave the bottoms open if possible and don't forget the holes in the horizontals.life is good
GMT+8, 2025-12-31 11:41 , Processed in 0.095500 second(s), 18 queries .
