Toyota pickup rack
发表于 2021-8-31 22:34:27 | 显示全部楼层 |阅读模式
Just a small rack to help move materials, ladders, my canoe, etc. made mostly from some left over 1.5" 0.125" wall tube. Cheers! ~Justin Manufacturing EngineerWWU Vehicle Research Institute c/o 2010
Reply:looks functional.  Great!
Reply:Thanks! I'm happy with it.~Justin Manufacturing EngineerWWU Vehicle Research Institute c/o 2010
Reply:Looks OK to me. But I would add gusset pieces running across the bed too, like the two you have running fore and aft on the sides. This will stiffen it up some, from moving side to side with a heavy load resting on it. Plus it gives you another place to use as a tie down point on each side. But that's just me.
Reply:Looks good. I need to build me a utility rack for my toyota.Sent from my iPhone using TapatalkLincoln Pro Mig 180HF Stick/Tig Inverter WelderLincoln AC225s
Reply:Nice work.  I hate it when guys use their cabs as material racks.  The guy before the guy that had my 89 Yota 4x4 before me was a carpenter, and used the cab for a rack.  I've since built a full rack from round tube.-AaronJet 17.5" Drill Press1942 South Bend 16x84 Lathe1980s Miller 320A / BP --- 2013 Power Mig 2562012 Jet 7x12 Horizontal BandsawVictor O/A Setup
Reply:Originally Posted by rabidchimpNice work.  I hate it when guys use their cabs as material racks.  The guy before the guy that had my 89 Yota 4x4 before me was a carpenter, and used the cab for a rack.  I've since built a full rack from round tube.-Aaron
Reply:Thanks guys! It's been working great! Very stout~Justin Manufacturing EngineerWWU Vehicle Research Institute c/o 2010
Reply:A couple updated pics with the final product ~Justin Manufacturing EngineerWWU Vehicle Research Institute c/o 2010
Reply:Looks good man
Reply:Not badSent from my iPad using TapatalkWill   Supports Autism Awareness                            My ToysBobCat 225 PLusMillermatic 130Miller Spectrum 300 CutmateEverlast Power Tig 185 Micro April is Autism Month .
Reply:Looks good. I like the fact you can remove the rear when you dont want it in the way. Thats the way I made mine and I love it. If you cant fix it with a hammer, it must be an electrical problem."Boy, everyone starts with a full bag of luck and an empty bag of experience. The trick is to fill the bag of experience before the bag of luck is empty."-Grandad circa 1990ish
Reply:Originally Posted by sausage450rI haul 20ft lengths by running it into the cab, and I have a 5ft extension that slides into my receiver.
Reply:Originally Posted by larpheadLooks good. I like the fact you can remove the rear when you dont want it in the way. Thats the way I made mine and I love it.
GMT+8, 2025-12-31 01:13 , Processed in 0.118414 second(s), 18 queries .
