Wire Stuck (SP125 Plus Lincoln)
发表于 2021-8-31 22:34:26 | 显示全部楼层 |阅读模式
Guys,What would suddenly cause this?  I don't use my welder all the time as I do it mostly for home projects, hobbies etc.  The wire does seem to have a film on it.  Probably a little corrosion.  I think the tip is an .035 and the wire I'm using is .025??  Can't remember for sure.I tried pulling the wire out, but it wouldn't give.  I looked at the wire feed and it was a little wadded up, but I cut that piece off so it wouldn't add to the problem.  Any idea how I can get it out?  If I do, I'm getting some new wire.This is the first time it has happened, and I've owned the little welder for almost 10 years.
GMT+8, 2025-12-31 01:13 , Processed in 0.102415 second(s), 18 queries .
