Govener on old Lincoln Gas machine
发表于 2021-8-31 22:34:24 | 显示全部楼层 |阅读模式
A friend called me tonight and said is machine will hit WOT when it starts. Something with the govener I'm sure any ideas? I have no idea how old the machine is. Magneto, down draft carb. and a flathead 4 cyl. redseal engine.That about all I know about it.
Reply:it stays this way? or will it idle down after afew seconds?
Reply:He keeps it on high idle all the time. It just keeps reving up. Gov not working at all. I would blow it it were to keep running.
Reply:what kind of idler does he have on the unit?
Reply:Got me on that. I go look at it tomorrow and get all the info I can from him. Thanks!
Reply:It most likely has the vacuum bellows type idler, which is what my '47 SAE300 has. High idle should be around 1500RPM, low idle at 800 to 900RPM, and load speed at 1300 to 1400RPM.RD 1984 Chevrolet C30 welding truck1966 Lincoln SA200 Continental F162 1942 Lincoln SA200 Hercules IXB-51991 Lincoln LN25
Reply:What we normally do in a case like this is break the governor/carb connection - you can do that at either end with the ball rod connection. Then, with one hand on the carb throttle holding machine to idle, start engine and gradually allow speed to increase. As it rises, observe the governor arm - if it moves to the left - counter-clockwise - as speed increases, gov is ok. Most times, someone has adjusted the governor spring which is below the arm. The condition you desire is to have the gov half way in its travel at max rpm. Lock the idler open to get it out of your way. Governor very seldom goes bad, but they are available at reasonable prices on used market. Keep in mind that the governor is key to timing. If you do not remove the bottom gov bolt, you cannot upset the engine timing. weldersales
GMT+8, 2025-12-31 08:49 , Processed in 0.188168 second(s), 18 queries .
