lincwelder question
发表于 2021-8-31 22:34:23 | 显示全部楼层 |阅读模式
i found a ac stick welder 225 amps that is used. everthing is in good condition cables, clamp, rod holder etc... it has a heavy duty power cord that is real thick. my question is it has a white dial selector. is there a difference between the ones that have a black dial and a white dial?thanksjdw
Reply:One is black, the other is white.If they're both Lincoln AC 225 welders, should be no diff.
GMT+8, 2025-12-31 01:11 , Processed in 0.109885 second(s), 18 queries .
