GTAW and SMAW
发表于 2021-8-31 22:34:23 | 显示全部楼层 |阅读模式
Hi all expat here,Do you guys know how to calculate the electrode/filler rod for a pipe weldment? I have a norms for that but didn't specify it is for GTAW or SMAW. Let said i have to use 33kgs of electrode for one joint. How many percent of 33kgs is for GTAW(filler rod) and SMAW(electrode)?
Reply:I'm no pipe expert by any means but if the joint calls for a combo of gtaw and smaw, the root will obviously be gtaw with fill and cap smaw. 33kg is almost 73lbs. That's a large pipe joint.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:Originally Posted by snoeproeThat's a large pipe joint.
Reply:Originally Posted by snoeproeI'm no pipe expert by any means but if the joint calls for a combo of gtaw and smaw, the root will obviously be gtaw with fill and cap smaw. 33kg is almost 73lbs. That's a large pipe joint.
GMT+8, 2025-12-31 08:50 , Processed in 0.112637 second(s), 18 queries .
