L-Tec VI 300 w/ Miller wire feeder
发表于 2021-8-31 22:34:16 | 显示全部楼层 |阅读模式
Not mine, but is on Craigslist Orlando.  $100.A little rough, 3 phase welder, no gun or power cords.  I have no interest, but I did go see it.  Don't need another project.FredMiller 330 A/BPDynaflux R1000 coolerLinde HDA-300 HP-18 torchHobart BetaMig 251Hobart Handler 135 Campbell Hausfeld 80P&H 181 Arc Century 295 Arc Hypertherm Powermax 900 Plasma cutterSeveral Oxy/Acc torch and tanks
Reply:I could really use that wire feeder, did it seem to be in good shape or working condition? Too bad i`m a million miles away.
Reply:The XR feeder is about $2K new and the XR gun is about $1K new.   Any Spoolmatic 15/30A spool gun can be converted to use as an XR push-pull gun.  For $100, I'd buy the machine, look for a used Spoolmatic 30A, buy the $80 wire conduit for it, make an adaptor pigtail for the remote connector, and voila, instant push-pull aluminum mig welding for peanuts, if you have the 3-phase power to run the power supply, assuming it's 3-phase-only.  Most of those larger shop migs from that era were 3-phase.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
GMT+8, 2025-12-31 03:42 , Processed in 0.092057 second(s), 18 queries .
