Lincoln R3R-400 Idealarc welder never used
发表于 2021-8-31 22:34:14 | 显示全部楼层 |阅读模式
Hi, I've got a Lincoln Electric R3R-400 Idealarc welder is basically brand new, never been used, never been hooked up to power, still on pallet. It's got some body damage- the previous owner said that the front lip got damaged while unloading it. Looks like the side got hit with a forklift or something. Other than that it's in great shape. Price is $900 OBO. 951-501-9798 Zach. or [email protected] are as follows:Look to the R3R-400 power source from Lincoln Electric for your heavy-duty stick welding needs. Whether you are using cellulosic, low hydrogen, stainless steel or hardfacing electrodes, the Idealarc R3R-400 produces smooth, quality arcs for consistent results day-in and day-out. The R3R-400 provides peace of mind with their traditional design for long life expectancy and low cost operation, calibrated current control knob for simple and easy procedure setting, and all weather protection including a powder paint finish for durability in the roughest environments. Need to do arc gouging? The R3R-400 from Lincoln Electric can help you do that too!* Polarity switch, voltmeter and ammeter are standard* The R3R-400 produces quality, low spatter, smooth arcs without pop-outs. Line voltage fluctuations of up to ±10% are handled by the R3R compensation function to keep the output constant* Easy to operate* Calibrated current control knob makes procedure setting simple and easy* Smooth arc makes it easy to weld with mild steel, low hydrogen, stainless steel and hardfacing electrodes* Stackable case design with built-in lift hook allows for easy storage and handling. Machines can be safely stacked three high to conserve floor space* Submersion dipped transformer assembly for added corrosion and moisture protection* Totally enclosed fan motor is permanently lubricated* Arc gouging is possible with the R3R-400 with up to 5/16" (7.9mm) diameter carbon electrode* The R3R-400 can be used for limited DC TIG welding – simply add TIG accessories and shielding gas* Manufactured under a quality system certified to ISO 9001 requirements and ISO 14001 environmental standardsProcesses:* Stick* TIG* GougingApplication:* Specifically suited for critical welding applicationsSpecifications:* Input Power: 230/460/3/60
* Rated Output:
o 400A / 36V / 60% (Current/Voltage/Duty Cycle)* Input Current @ Rated Output:o 74/37A* Output Range:o 60-500A Max. OCV: 67V* Weighto 402 lbs* Overall Dimensions: 27.5" H x 22.3" W x 33.1" D
Reply:Hi Zake you may want to post your location just in case someone is curious where you are located if they want to look at it & give it a try.If you want to post your location, show your personal avatar, or have a signature on each post telling fellow members where you are located; an avatar of you or your shop, and a signature telling fellow members what types of equipment you have, you can do it all by following these steps:1. Locate and click on USER CP2. Under YOUR CONTROL PANEL, YOUR PROFILE, click on EDIT YOUR DETAILS3. In the EDIT YOUR DETAILS, you can enter Optional Information and Additional Information such as your Location (an other info)4. While in USER CP you can explore some of the other functions - Avatar: you can have picture of you, your shop, your wife, children, dog, etc (keep it clean- no nudes)- Signature: you can list all your equipment, a link to your shop, or maybe some witty sayingCo-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.&  2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
Reply:if u still got this i will take it depending on location
GMT+8, 2025-12-31 12:14 , Processed in 0.099167 second(s), 18 queries .
