Tig welding stainless and steel with , oh crap.
发表于 2021-8-31 22:34:12 | 显示全部楼层 |阅读模式
I love the way stainless tig welds, but I really don't have much experience doing it. I was welding these legs on a small table made with scrap. I was in a hurry and grabbed some rods and everything was going well except for the last short bead. Dang I thought, this bead ain't going very well. I quickly adjusted the gun, and backed off on the pedal and was able to make it flow. I should have stopped after the first two dabs of filler, but decided to finish the bead anyway. I then said, what the heck is wrong with this? (I know the answer, but can you tell by the appearance?)  Hint: I'm an idiot.  Miller Bobcat 250Syncrowave  200Millermatic 252Spoolmatic 30ASpectrum 625 X-TremeMaxstar 150SVictor O/A torchesDewalt angle grindersWelded on/off for over 40 years.
Reply:Aluminum filler don't work very good....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Aluminum filler? Its hard to see much with my phone.Airco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power) Hobart MIG
Reply:looks a little like sil bronze or aluminum filler?!Benson's Mobile Welding - Dayton, OH metro area - AWS Certified Welding Inspector
Reply:Dammit zap! Few seconds too late.. Guess you win the prize this time.Airco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power) Hobart MIG
Reply:either you were pumping too many amps into in or you were using aluminum filler metal.....grind it out and do it again I would say...SnailHouse_Projects--For All Your Turbo and Off-Road Needs Import and DomesticMiller Dynasty 200Miller Syncrowave 250Miller 251Lincoln 250'69 Lincoln SA-200 MILLER KILLER!Thermal Dynamics PlasmaPakmaster 100XL
Reply:Yep Zap you win....   I grabbed an aluminum rod by accident. I should have recognized the error on the first dab. Dabbit.Miller Bobcat 250Syncrowave  200Millermatic 252Spoolmatic 30ASpectrum 625 X-TremeMaxstar 150SVictor O/A torchesDewalt angle grindersWelded on/off for over 40 years.
Reply:Hey, it's cheaper than explosion welding. MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2025-12-31 08:09 , Processed in 0.095230 second(s), 18 queries .
