Stubby Gas Lens Body compatibility
发表于 2021-8-31 22:34:11 | 显示全部楼层 |阅读模式
Is there a stubby Gas Lens Body - 3⁄32” 2.4 mm (like the 45V44) compatible with a wp 18 water cooled type torch?
Reply:The 18 takes the same parts as the 17 torches do. I'm not sure what lens you are asking about, so I can't compare it to anything, but if it fits a 17 series torch it will fit the 18's..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:When should a gas lens be used?Is there a particular type of metal or thickness where it is useful?Miller 211Hypertherm PM 451961 Lincoln Idealarc 250HTP 221  True Wisdom only comes from Pain.
Reply:Originally Posted by 7A749Yeah. CK sells one, HTP sells them too.The set I have is specifically made for use with 17/18 size torches.I have one on my 18 torch right now as a matter of fact.
Reply:Originally Posted by RubberduckWhen i looked at Parweld site, they didn't have it. The reason i'm asking is because there are different thread types between some torches.
Reply:Originally Posted by John TWhen should a gas lens be used?Is there a particular type of metal or thickness where it is useful?
Reply:CoolThanks for the info. I got one with my used welder..I will have to try it.Miller 211Hypertherm PM 451961 Lincoln Idealarc 250HTP 221  True Wisdom only comes from Pain.
GMT+8, 2025-12-31 08:15 , Processed in 0.111643 second(s), 18 queries .
