much needed help (TIG)
发表于 2021-8-31 22:34:11 | 显示全部楼层 |阅读模式
Got myself a tig setup a few days ago and im not sure what im doing wrong my beads are looking like crap and im getting this yellowing residue oh and my tungsten will run fine for a few second then completely shoot an arc in every direction i thought the residue was from not enough argon so ive been playing the pressure but getting same result ive clean the crap out of the steel tried new tungsten if anyone can enlighten me PLEEASE!!!!machine is miller xmt 304 (DCEN) aRGON: 10-20 filler rod ER70S-2
Reply:Are you SURE its on straight polarity? If it is the it has to be a shielding problem. Is it pure argon or a mig mix? Can you hear/feel argon flowing through the cup? Have a short stickout/arc length? Check everywhere that the argon flows for leaks. Every connection and every hose, use a little soapy water.Grind the steel clean before tig welding. Welding dirty steel is just going to make problems harder to find.Airco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power) Hobart MIG
Reply:You know I will check the gas I did grab the tank from a mig machine I sure hope it's gonna be a simple fix I over lookedLast edited by jesse07; 02-18-2014 at 10:29 PM.Reason: Miss spell
Reply:Gas problem.Can't run mig gas lad....Miller Dynasty 200DXMiller Spectrum 250DMiller Millermatic 200Bunch of old blue dinosaurs....
Reply:Originally Posted by jesse07You know I will check the gas I did grab the tank from a mig machine I sure hope it's gonna be a simple fix I over looked
Reply:just checked the tank this morning sure enough 75 / 25% mix woops!!!!! thanks guys
GMT+8, 2025-12-31 03:42 , Processed in 0.100538 second(s), 18 queries .
