bucket work
发表于 2021-8-31 22:34:08 | 显示全部楼层 |阅读模式
be easy on me,i dont have much experience
Reply:Nice work. Are the sides AR plate?
Reply:Looks good, did you replace the cutting edge or just build it up. What size machine looks like maybe a pc300?
Reply:The sides are hardox 500, we had a piece on hand. The wear bars on the bottom  are Ar. Cutting edge didn't get replaced, just built up. Machine is a Pc400
Reply:Looks pretty good!
Reply:Thanks guys
Reply:What process did you use to button it up???Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:Was using solid .045 wire in the miller xtreme suitcase wire feeder. I've heard before it's better to use duel shielding flux core wire?
Reply:Originally Posted by abaralnekWas using solid .045 wire in the miller xtreme suitcase wire feeder. I've heard before it's better to use duel shielding flux core wire?
Reply:The edge was still in good shape? The top side of the shanks were likenew, bottom was worn so I built them up with hard face and added 4" strips of ar in between. Should get plenty more digging from it and them it will be replaced.
Reply:Very nice work! Keep postin pics."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Looks really good to me."The reason we are here is that we are not all there"SA 200Idealarc TM 300 300MM 200MM 25130a SpoolgunPrecision Tig 375Invertec V350 ProSC-32 CS 12 Wire FeederOxweld/Purox O/AArcAirHypertherm Powermax 85LN25
Reply:How did you strip the old wearbars air arc?
Reply:Originally Posted by abaralnekThe edge was still in good shape? The top side of the shanks were likenew, bottom was worn so I built them up with hard face and added 4" strips of ar in between. Should get plenty more digging from it and them it will be replaced.
Reply:The wear bars on the bottom are Ar. Cutting edge didn't get replaced, just built up.
Reply:Looks great. I would suggest switching to a 1/16 dual shield it will speed up production quite a bitMiller trailblazer302Millerxmt304millermatic 200lincoln squarwavelincoln SA250lincoln SAE400Climax BB5000
Reply:Thanks! The wear bars were cutting off with a torch. Definitely some scalloping going and your right it's because of the edge thinning. I blame opperator abuse. The bucket has dug nothing but blasted ledge and was just past 1 year since a fresh rebuild. He must have used the bucket to doors of grading of the ledge floor, only the bottom side of the edge was worn. I welded 1" thick ar wear bars in between the adaptors on the bottom side. Still got the scalloping but should wear for awhile
Reply:In the Klondike gold fields the inside of the bucket generally wears out before the wear bars on the back of the bucket. We had a PC400 feeding the sluice plant at 400 yards an hour and every spring was bucket rebuild time.
GMT+8, 2025-12-31 01:30 , Processed in 0.071730 second(s), 18 queries .
