Outdoor mount for Axis camera
发表于 2021-8-31 22:34:06 | 显示全部楼层 |阅读模式
Last night I whipped out an outdoor mount for a camera that will be mounted at a scale. It's a pretty neat setup. The truck rolls onto the scale. The scale controller is tied to the server and it stores and image of the truck along with they weight. The driver doesn't have to get out of the truck. I cut a few inches of 6" well casing. Yes this will be heavy duty... it's for the farm. Next I plasma cut a circle with cut out for the cable. I then drilled and tapped for some #8-32 screws on the mill. Power tapping made it quick. Yes, I missed the mark on first screw how and had to drill and tap twice. It was late.  I then welded a length of rigid pipe and topped it off with a 10" circle. I had to adjust the upright a bit for the camera to fit. It was late and a hammer made quick work of it.
Reply:awesome! very heavy duty! I'd probably use pvc pipe becuase that is what I have lying around . LOL.
Reply:nice work f.h. i been thinking about a camera for the front of my garage and something like that is what i need. is that a wireless set-up?i.u.o.e. # 15queens, ny and sunny fla
Reply:Originally Posted by AluminumWelderawesome! very heavy duty! I'd probably use pvc pipe becuase that is what I have lying around . LOL.
Reply:Cool setup for sure, nice work!Sent from my SPH-L710 using Tapatalk
Reply:Originally Posted by forhireI know you were kidding but PVC would work if you glued/screwed it. Interesting idea. Lighter weight.It's POE wired system. You still have to power the camera so it's easier to pull CAT6 than dropping AC power. These cameras have edge storage along with all the normal push capabilities.
Reply:Originally Posted by docweldersounds great fh but exactly what is a cat6,poe and push what lol??
Reply:Originally Posted by adambowles00Cool setup for sure, nice work!
Reply:Originally Posted by forhireThanksBasically you run your ethernet cable to the camera and the power is delivered over the pairs not used for data. Mikel gave a good explanation. Thanks for your detailed description of POE. Push generally is used to describe when a server automatically pushes data to a client. In this case, because the camera has it's own web server, it pushes an image to storage when motion triggers. It's uploaded automatically would be another way to say the same thing.
Reply:Test the fit of version 2.0 today. Amazing what happens when you sleep on an idea. I didn't scrap the original one... I just came up with a better idea for this location. The other mount will used in another location but this new version fixed a few issues with the first mount. If I build more of these I'll do a few things different but they will mostly be build order. Biggest change was eliminating the box with the key hole and replaced it with a plain circle for the junction box. This makes it a lot easier to use the junction box.Here's a few photos:Last edited by forhire; 03-29-2014 at 10:43 PM.
Reply:Here's the rest of the photos.
Reply:very nice looking work fh.i.u.o.e. # 15queens, ny and sunny fla
Reply:Originally Posted by docweldervery nice looking work fh.
Reply:Nice job.  Super heavy duty too!
Reply:Originally Posted by Murphy's lawNice job.  Super heavy duty too!
Reply:Originally Posted by forhireThanks. I just used stuff I had laying around. Hopefully the heavy steel doesn't become too much of a heat sink in the summer.
Reply:If a skud missle hits the top of that thing, nothing will happen to it. It will just laugh at it. Nice job.www.tjsperformance.comDynasty 300 DXHTP 240HTP Microcut 380Hyperthem 85JD2 Hyd Bender and HF Hyd Ring Roller all in one =(Frankenbender)Bpt. Mill/DRO4' x 8' CNC Plasma TableInstagram: tjsperformanceYT: TJS Welding and Fabrication
Reply:Wow! That's one awesome and solid build. Great design, it will hold and protect very well the camera.
GMT+8, 2025-12-31 01:29 , Processed in 0.098108 second(s), 18 queries .
