Filler??....What Filler....?
发表于 2021-8-31 22:34:06 | 显示全部楼层 |阅读模式
3/32" Red tungsten..SHARP!!!....Check!Footpedal....Check!Positioner....Check!#5 Cup....Check!Filler....NO.I get all the small fun jobs......zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:perdy!There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Thats some very nice work.Care to explain what it is?
Reply:Did you get a bonus for saving the boss man some money on filler? GravelThe difference between theory and practice is that in theory there is no difference.
Reply:Originally Posted by Canadian WeldingThats some very nice work.Care to explain what it is?
Reply:Originally Posted by GravelDid you get a bonus for saving the boss man some money on filler?
Reply:Originally Posted by zapsterNo but why add it when you don't need it...All 316 stainless......zap!
Reply:Sweet! I need a tig machine!
Reply:Good engineering. No filler needed. Make the cuts a little different. SHAZAMM !Bubble gumTooth pixDuct tapeBlack glueGBMF hammerScrew gun --bad battery (see above)
Reply:Originally Posted by zapsterAll 316 stainless...
Reply:Originally Posted by DSW...For those that don't know, that's why he can get away without using filler.
Reply:Originally Posted by Mikel_24Is stainless "flexible" enough so it doesn't crack after welding without filler? (I understand this is what happens usually with aluminum... no filler = cracks) I never tried TIG and any other welding method requires filler in the equation, that's why I am asking.Mikel
Reply:Has anyone ever checked Zap's pluse?  I think he's a machine!
GMT+8, 2025-12-31 03:43 , Processed in 0.096067 second(s), 18 queries .
