Newest work project.
发表于 2021-8-31 22:34:04 | 显示全部楼层 |阅读模式
Some meatball fabrication from yours truly. 4" schedule 40, some MIG, some stick. This is an addition to a pneumatic ore conveyance system. Basically a BIG roots supercharger powered by an electric motor with a venturi setup to draw ore (perlite ore, this grade is the consistency of powdered sugar.) into the air stream. The author in his natural environment...Wye pipes and valves installed...Sent from my iPhone using TapatalkUsing Tapatalk
Reply:More pics...Drop box in place...Existing pipe run to ore bins(I ran the top run about 3 mos ago.)Sent from my iPhone using TapatalkUsing Tapatalk
Reply:Finished Venturi/air feed. Sent from my iPhone using TapatalkUsing Tapatalk
GMT+8, 2025-12-31 01:33 , Processed in 0.097256 second(s), 18 queries .
