Champion 10K red light on board
发表于 2021-8-31 15:02:02 | 显示全部楼层 |阅读模式
OK, I have searched high and low. My Champion 10,000 loses power after a few seconds of running and a red light comes on on the board. I have read every thread I can find and the few times this light was mentioned no one ever explained what it means. I need help.
Reply:The light means the unit has been overloaded either power or weld output.PM me an email address and I can send you some troubleshooting information.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:I got it duaneb55, went to do the test on it. First thing I checked was the brushes. When started they have 125 to 130 volts DC, has power for maybe 30 seconds then the red light comes on and lose power. Voltage slowly drops to around 30 volts, red light goes out, power returns and it goes through the process of tripping out again. The board looks good with no burnt spots.
GMT+8, 2025-12-18 16:31 , Processed in 0.080461 second(s), 18 queries .
