Repainting a Lincoln question
发表于 2021-8-31 22:34:02 | 显示全部楼层 |阅读模式
I recently picked up an old Lincoln AC-225-S that I'm in the process of reconditioning. The sheet metal had a lot of surface rust that I'm cleaning off. I'm going to repaint both the inside and outside of the unit. Do I need to use a special type of paint or primer?  Does anyone know what manufacturer's color would come close to matching the original?
Reply:Just use a good epoxy enamel or acrylic enamel.  Make sure you get a good tooth on the bare steel (something for the primer to stick to).Various GrindersVictor Journeyman torch200cf Acet. 250cf oxygenLincoln 175 plus/alpha2 gunLincoln v205t tigLincoln 350mpEsab 650 plasmaWhen you can get up in the morning, Its a good day.Live each day like its your last.
GMT+8, 2025-12-31 03:42 , Processed in 0.114099 second(s), 18 queries .
