no fire
发表于 2021-8-31 22:34:01 | 显示全部楼层 |阅读模式
I'm putting a different engine on my welder I wanted to try the engine so I hooked up the coil.Then hooked up a battery charger to the engine to crank it up and I have no fire. Do I have to run 12volts to anything other than the starter. It is a onan p218 engine. Mach 1390
Reply:Unless it has magneto you will need voltage to the ignition ckt.DennisThermal Arc 185-TSWMillermatic Challenger 172VictorO/AAtlas Craftsman 12 by 24 LatheEsab PCM-875Wholesalem Tool Mill-Drill
GMT+8, 2025-12-31 12:14 , Processed in 0.198858 second(s), 18 queries .
