PT 185: water cooled questions ?
发表于 2021-8-31 22:34:01 | 显示全部楼层 |阅读模式
Hi-I was given a PT- 185 as a gift this past holiday.  I have a few questions about changing my machine from an air-cooled torch setup to a water unitI plan on upgrading to a water torch and closed loop cooler system. Can anyone recommend what brand water torch I should purchase. Should I go with the Lincoln water torch package or something like a Weldcraft ? Lastly, does anyone have any advice about building a closed loop water cooler? How many GPM should the system pump flow? Should the system operate on a thermostat? How much cooling capacity should the system have? Can glycol be run in the cooling system (my shop isn’t always heated)?Any words of advice would be much appreciated!Thanks-Graham
GMT+8, 2025-12-31 03:42 , Processed in 0.111833 second(s), 18 queries .
