NEW GUY, tig cooler ?'s
发表于 2021-8-31 22:33:58 | 显示全部楼层 |阅读模式
I am a new guy to the forum and new to tig welding, trying to learn tig welding is hard when my hand is burning after 5 minutes. Will a water cooled torch help this problem? I have a lincoln 225 precision tig, I have found a good deal for a miller coolmate 1 cooler (alot cheaper than the lincoln model) will these two units function together?Thanks!
Reply:yes sir a water cooled will help a lotidealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:Originally Posted by rwurbanI am a new guy to the forum and new to tig welding, trying to learn tig welding is hard when my hand is burning after 5 minutes. Will a water cooled torch help this problem? I have a lincoln 225 precision tig, I have found a good deal for a miller coolmate 1 cooler (alot cheaper than the lincoln model) will these two units function together?Thanks!
Reply:every one ive talk to says the coolmate 1 is realy noisyso noisy they would not buy another one
Reply:how about the coolmate 3? I can get some good deals on them, plus the lincoln cooler is almost 4' long.
Reply:i would go with the 3
Reply:I am using a Coolmate 3 with my Dynasty 200dx and it works great. And it's not noisy at all.
Reply:i have a coolmate 3 forsale 350 plus shipping its still in the box still stapled shut never even opened it i was gunna have a tig for aluminum and steel and just never went with the steel one. pm me
Reply:What part of the torch were you holding? What do you do about your weldments just after you weld them?
GMT+8, 2025-12-31 01:29 , Processed in 0.102672 second(s), 18 queries .
