Dual saw
发表于 2021-8-31 22:33:58 | 显示全部楼层 |阅读模式
This may have been asked before, but does anyone have experience with a dual saw?
Reply:Originally Posted by c craneThis may have been asked before, but does anyone have experience with a dual saw?
Reply:is that the one they are pushing on tv showing the fireman cutting a car apart? i cant figure out how they make the blades run in opposite directions...
Reply:the one i bought from sears several years ago was junk.motor overheated easily and a brush holder melted. i would think today's tools are improved as that one was one of the first on the market. the cutting action was good on steel and aluminum.
Reply:I have looked for reviews of the dual saw and all i can find is reviews of the infommercial, I wouldn't give it a second look for several reasons...HH187Hobart 500i plasma cutterClark 4.5" GrinderDewalt 14" chop saw30 gallom 1.6 hp compressor10 gallon pressure pot sand blasterlots of hand tools
Reply:Its also known as a "twin cutter" or "twin cut saw".  You may want to do a little research with those names.  (Sears calls the Craftsman model a twin cutter, and the reviews aren't so great).It has two concentric counter-rotating shafts for the blades, and uses a wax lubricant between the two blades, with special blades that have zero kerf on the inner sides.A common complaint is a low duty cycle that burns out the motor after just a few minutes of continuous operation.I'm not sure what you'll be wanting this for, but for woodworking in those odd plunge cuts where other tools don't work well, I really like my Fein.
Reply:Thanks for the replys-----i got a gift card from my kids and was going to get one yesterday, but they were out of stock and now i'm glad they were----now  i think i will get a cut off saw.
Reply:Thought I saw a porta cable saw with the dual opposite rotating blades. Owner liked it at the timeG
Reply:I purchased the dual saw as seen on TV.  It worked OK, when I purchased it I told them I only wanted it if it would cut 1/8” propane tanks.  http://www.amazon.com/Twincut-Techno...5139695&sr=8-1It did, but it really labored so I sent it back and got me a Plasma cutter.
Reply:.And here I was expecting to see a ten foot bar with a Stihl 90 on each end!I couldn't find a picture of one, but did find separate pictures of the 090 Stihl, and of a double-ender; pictures might be 'copyrighted', so here the links are instead:Stihl 090 on stump Stihl 090, right side viewDouble Ended SawDouble-ender in useThese were Real Saws; they Never quit!  (Not often, anyway)[ and many are made in the USA! ]
GMT+8, 2025-12-31 03:42 , Processed in 0.156170 second(s), 18 queries .
