millermatic 185
发表于 2021-8-31 22:33:56 | 显示全部楼层 |阅读模式
Looking at a used millermatic 185 from an individual and was trying it out and while welding, after @ 3" of welding a bead the wire feed stopped. Opened up side cabinet and found a circuit breaker popped in machine. Reset breaker, welded a 3" bead, wire stopped feeding, and found breaker popped again.I'm looking for some sound advice. Does this sound like an issue on the circuit board?Thanks.
Reply:i looked at the owners manual trouble shooting guide, and it was no help. i would only consider it if it is under $200Dynasty 200DXPassport plus w/ spoolmate 100victor 315c oxy/(act and prop)Miller digital elitemilwaukee power tools
Reply:I would post it at the http://www.millerwelds.com/resources...ng-Discussions and let one of the techs jump on it or email Miller directly...BobBob WrightSalem, Ohio  Birthplace of the Silver & Deming Drillhttp://groups.yahoo.com/group/southbend10k/http://groups.yahoo.com/group/sawking/1999 Miller MM185 w/ Miller 185 Spoolmate spoolgun
Reply:Which CB is popping CB1 (bottom one) or CB2 (top one)...BobBob WrightSalem, Ohio  Birthplace of the Silver & Deming Drillhttp://groups.yahoo.com/group/southbend10k/http://groups.yahoo.com/group/sawking/1999 Miller MM185 w/ Miller 185 Spoolmate spoolgun
Reply:I believe it was the top breaker, I traced the wires to the contactor that feeds the drive motor. Thanks.
Reply:Thanks for your help Turk and Bob; figured it out. The flat connector on the pc board, pins 1 and 3 were burnt lightly and wasn't making poor contact. Cleaned male pin on board and popped out the socket and cleaned those good and machine is working good. Not that they need replaced but I wonder where a guy could buy them sockets at??Thanks again.
Reply:I have had good look at this site on these type components.http://www.onlinecomponents.com/
GMT+8, 2025-12-31 12:14 , Processed in 0.115699 second(s), 18 queries .
