3-phase vs 1-phase voltage?
发表于 2021-8-31 22:33:53 | 显示全部楼层 |阅读模式
Hello, are 220v welding machines strictly 3-phase or can they be operated on 1-phase 220v supply?
Reply:220 is an old voltage standard in North America, 240 has been the standard for quite some time, with that said my newish Miller welders are plated to operate at 230/460 volts.   The voltage alone is not what makes a welder singe phase or three phase, some welders work on either 1 or 3 phase power, you have to look at the specific machines power requirements.    There are many three phase "only" machines that CAN be used on single phase, the do use a lot more current on single phase.  SteveSteve from SoCal now in HutchMiller Dynasty 300DX Coolmate3 Speedway TorchMiller XMT 450 MPa plus with D-74 MPa Plus Miller Bobcat 225 NTHypertherm Powermax 45And a whole bunch of machines
Reply:Originally Posted by rapalashadHello, are 220v welding machines strictly 3-phase or can they be operated on 1-phase 220v supply?
Reply:Lower voltage 3 phase power in my area comes in 208, 460 and 575v options that I have seen. My Lincoln ideal arc 250 will run on 230v/460v/575v but single phase only. It can be wired internally to run on one phase (I think it's actually 2) of a 460v or 575v 3 phase power supply. But it's still running on single phase power.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:Some multi family residential installations use wye connected three phase. Typically these offer three phase 208 Volts or single phase at 120 or 208. More common is single phase 240/120 as Mike says.An optimist is usually wrong, and when the unexpected happens is unprepared. A pessimist is usually right, when wrong, is delighted, and well prepared.
Reply:Originally Posted by Willie BSome multi family residential installations use wye connected three phase. Typically these offer three phase 208 Volts or single phase at 120 or 208. More common is single phase 240/120 as Mike says.
GMT+8, 2025-12-31 01:30 , Processed in 0.111311 second(s), 18 queries .
