Inside of an AHP alphatig foot pedal
发表于 2021-8-31 22:33:53 | 显示全部楼层 |阅读模式
I am 99% sure that if someone had a desire, they could substitute a SSC controls L10000 potentiometer foot pedal for the standard AHP foot pedal. I took my foot pedal apart and it is a B10K linear potentiometer and a momentary switch. All you would have to do is buy a GX 16 5 pin circular plug and solder it onto the SSC pedal. I even have the pinouts for you all.Pin 1=purple=microswitchPin 2=yellow=microswitchPin 3=blue=pin 1 of the potPin 4=green=pin 2 of the potPin 5=black=pin 3 of the potMiller Multimatic 255
Reply:That's pretty cool.Craftsman 90 amp Arc welder
Reply:Must have picked up a second gen Alpha, minr has the seperated 2-3 plugs, 2 prong for both torch switch and foot pedal, and the 3 for the actual "pedal" internal potentiometer.
Reply:Louie1961, good stuff. The only thing to be aware of is the connector's part number. I've got a 2014 AHP Alpha TIG, and thought the connectors were GX 16-5, based on the pictures on the interwebs. So I ordered those cheap, actually shipped from in the USA, only to find out they were too small and what I needed were GX 20-5. Yes, I should've measured gooder. Anyway, both seem to be available, albeit the GX20-5 I got only seemed available from China but only took a few weeks to get over here. The 16 and 20 refer to, I believe, the the approximate size of hole these connectors panel mount in (in mm). Just measured my connectors, the GX16-5 panel mount thread diameter (panel mount hole diam.)  and came up with 15.75mm, the GX20-5 panel mount hole is at 18.70mm. Hope this helps.
Reply:Just made a pinout for my 2014 AHP Alpha TIG 200X foot pedal. Pretty much the same as Loui1961's. Noticed in your pinout Louie1961 that you list a purple wire on pin 1. Unless my very slight, red-green color deficiency has gone rogue, I see a brown wire for pin 1 for the contact switch, both in your picture and on my foot pedal.Foot Pedal ------>-------GX20-5 connector (female)switch  ------------- brown -------pin 1switch  ------------- yellow -------pin 2pot (leg, pin1) --------blue --------pin 3pot (wiper, pin 2) ----- green ------pin 4pot (leg, pin 3) ------- black -------pin 5Also made some resistance measurements for the pot and pedal position, with my pedal (values may vary):Pot value with pedal UPblue - green = max pot value (8.28 kohms)black - green = min. pot value (598 ohms)Pot value with pedal DOWNblue - green = min. pot value (1.0 ohms)black - green = max. pot value (8.71 kohms)Been taking notes for my DIY wireless foot pedal project. Picture is of what I've noted. Not great quality photo, but the above notes should be the same. I agree with you about the SSC Control foot pedal. The model L10000-S looks like it would work for ~$90. The "-S" is for the momentary switch addition, for an extra $20. http://ssccontrols.com/homepage-pote...ercontrols.htm Attached Images
Reply:Pretty cool stuff you're working on there, for the wireless foot pedal. 1st on WeldingWeb to have a scrolling sig! HTP Invertig 400HTP Invertig 221HTP ProPulse 300HTP ProPulse 200 x2HTP ProPulse 220MTSHTP Inverarc 200TLP HTP Microcut 875SC
Reply:Just an update for the pinout. I measured some voltages FROM the AHP TIG side, "control" connector, GX20-5 bulkhead, male pins.Foot Pedal ------>-------GX20-5 connector (female) -------->------- AHP "control" (GX20-5 bulkhead)switch ------------- brown -------pin 1 ----------------------------- groundswitch ------------- yellow -------pin 2 ----------------------------- + 11.8 VDC (w/ respect to pin 1)pot (leg, pin1) --------blue --------pin 3 ------------------- + reference voltage (0.134 - 8.40 VDC, varies with main amps)pot (wiper, pin 2) ----- green ------pin 4 ---------------------------- wiperpot (leg, pin 3) ------- black -------pin 5 ---------------------------- ground NOTE: This is for the 2014 AHP Alpha TIG 200X. 5 pin connector.
Reply:Originally Posted by OscarPretty cool stuff you're working on there, for the wireless foot pedal.
GMT+8, 2025-12-31 08:15 , Processed in 0.139343 second(s), 18 queries .
