Welding Helmet from Roark Supply
发表于 2021-8-31 22:33:53 | 显示全部楼层 |阅读模式
Hi, My name is Scott and i am very new to this forum. Actually, whenever I look for any answer related to welding, i end up on this forum. Lot of great suggestion and reviews on this forum. So, registered hereI am planning to buy a welding helmet and while researching i got to know about roark supply. As, I have never order welding helmets from Roark Supply. Anyone has any experience with these welding helmets they want to share. http://www.roarksupply.com/Welding-Helmets-s/236.htmIs the price reasonable?
Reply:They are a very small, two person operation.  They advertise significantly all over the internet.  Ads make them look much more impressive and larger than they are.  They frequently advertise items that they do not stock.  They tend to over promise and under deliver.  Pricing is not very competitive.  You might be well served by purchasing your welding helmet from a larger outfit like CyberWeld, IOC, etc.  You are more likely to have a satisfying experience.
Reply:Best to buy from a local welding supply co.
Reply:Originally Posted by farmer37Best to buy from a local welding supply co.
Reply:Buy a name brand helmet and not some off brand. Saving a couple bucks and having to buy another helmet because you can't find cover plates locally doesn't amount to any savings. Only frustration because you can't use a helmet you can't see out of.
Reply:Originally Posted by AKweldshopHow do you figure that?
Reply:Stt12 - where are you from?Local purchases are something I try to do whenever it makes sense - sometimes I can't really justify it - but I still watch and buy local when I can.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
GMT+8, 2025-12-31 03:43 , Processed in 0.116562 second(s), 18 queries .
