Does galvanized malleable iron tig weld good?
发表于 2021-8-31 22:33:52 | 显示全部楼层 |阅读模式
1 inch npt. Does this stuff crack easy?i wanna weld it to 1/16 mild steel. Thanks
Reply:Well it does not weld good but it does weld. Welded like crap!
Reply:tig brazed a piece of .018 brass screen to some 16 gauge steel tube, With 1/16 silicon bronze rod- took a while lol
Reply:What are you making?
Reply:Looks like it should hold depending on the application. Is it some sort of intake screen for a pump or something?Seen an a/c contractor that tried to do their own mechanical piping run flux cored wire around a 4"-3" threaded reducing coupling because the pliers could not tighten it up enough to stop the leak.   There was also no teflon tape or pipe dope.We were called to fix it and found out the threaded nipple was about 6" long and machine threaded all the way from one side, no wonder it leaked!!! Made new connections using weld neck fittings and those guys said "whell that's the same thing we did, can we help".TOO MANY TOOLS & NO MORE SPACE
Reply:Large bore crack pipe?GravelThe difference between theory and practice is that in theory there is no difference.
Reply:Come on man there's teenagers around here
Reply:Originally Posted by KelvinWhat are you making?
Reply:You can get that fitting NOT galvanized, for gas piping in walls. You can get basically the same fitting, but not cast, for electric conduit, welds like crap tho.-c-What is the sound of one knee jerking?
Reply:A one inch black steel coupling would weld fine. Much better then galvanized.
Reply:Is black steel and black iron the same thing? I got this from Home Depot 5 minutes before they closed. I should have waited to go to Parkrose hardware, they have a real nice collection
Reply:If it's for a recirculation system in a cooler, I'd probably use brass pipe and fittings - no corrosion possible.Keep that system as clean as possible.Brass screen on brass pipe maybe easier.Next time I'd make the fitting so you can change and replace the screen.
Reply:I can blow the crap off the screen.
GMT+8, 2025-12-31 03:42 , Processed in 0.125235 second(s), 18 queries .
