New to welding, nozzle stuck idk what to do
发表于 2021-8-31 22:33:48 | 显示全部楼层 |阅读模式
So a couple days ago i order the lincoln 210 mp after a lot of research. its my first welder, but i did weld a few times before i bought it. i did flux core the first day because the stores weren't open and then today i went and got some c25 mix and i start practicing my mig skills. soon after i gummed up the tip so i tried taking the whole nozzle off, but the whole gas defusser came of and then i tried pulling it apart with my dad and we couldn't get it. also when i put it together i only did hand tight. what should i do? I can't find any magnum 175l mig gun discussers either. thanks y'all
Reply:how gummed up is it? the nozzle should thread on the gas diffuser. put a wrench or channel locks on the diffuser and same on nozzle and try and separate them… If it is "gummed up" too bad you might of welded the two together  either way its good to have some spare consumables around- Christian M.C3 Welding & Fabrication - CNC Plasma Cutting-Mobile Welding-Custom welding and fabwww.c3welding.com
Reply:Originally Posted by camjeep3how gummed up is it? the nozzle should thread on the gas diffuser. put a wrench or channel locks on the diffuser and same on nozzle and try and separate them… If it is "gummed up" too bad you might of welded the two together  either way its good to have some spare consumables around
Reply:Originally Posted by jackrabbit41It could be welded on, I'll keep working at it and btw I got a 87 jeep comanche that I'm hoping to start build a rear bumper for
Reply:Unscrew or pull off the nozzle, put a wrench on the diffuser & unscrew the contact tip. Don't ever remember ever having to change a diffuser & I'm talking pallets full of flux core wire run through them. How the heck did you manage to mess that up?REAL TRUCKS DON'T HAVE SPARK PLUGS
Reply:Originally Posted by Old SkoolUnscrew or pull off the nozzle, put a wrench on the diffuser & unscrew the contact tip. Don't ever remember ever having to change a diffuser & I'm talking pallets full of flux core wire run through them. How the heck did you manage to mess that up?
Reply:Understand I say this w/ tongue in cheek: How would you do w/ a steel ball and a rubber hammer? I can't help you w/the problem but some pics would help get you help.                               MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:Originally Posted by mla2ofusUnderstand I say this w/ tongue in cheek: How would you do w/ a steel ball and a rubber hammer? I can't help you w/the problem but some pics would help get you help.                               Mike
Reply:Is that the type of gun that has left hand threads ?
Reply:Originally Posted by BlueweldersIs that the type of gun that has left hand threads ?
Reply:Originally Posted by jackrabbit41No It's regular and to post pics on here do I just have to go through a website like photo bucket and put in the image link?
GMT+8, 2025-12-31 12:14 , Processed in 0.108990 second(s), 18 queries .
