0-600psi (0-4000kPa) Bottom Mount Gauges
发表于 2021-8-31 22:33:45 | 显示全部楼层 |阅读模式
Have a number of these rescued from being chucked to the dumpster that were removed from new nitrogen regulators (low side of course).  USG, 1/4" male NPT connection.  Can ship as many as you need or are available via USPS Small / Large Flat Rate Box for the freight (PayPal works).  Hate to see them go to waste.  PM me with your info and how many.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Why were they removed?Miller Dynasty 300dxSpeedglas 9002XMiller Spectrum 375 XtremeLincoln PowerMig 255xtLincoln PowerMig 140cMilwuakee Portaband
Reply:Multiple feeds (cylinder bank) into a common manifold with a single gauge.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Thread update:Found out today these are complete sets - high side (0-6000psi) and low side (0-600psi posted originally).At least 12 sets currently available if you need/want them. Attached ImagesMM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Duane, PM sent..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Got another batch.  Same terms apply.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:are these gauges for gas only?   would they work with hyd oil?Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:An update to the thread update. There are two pressure range 'sets'.  6000/600psi (top) and 4000/400psi (bottom).Unfortunately, I do not have any 'No Oil' for use with these.:rolleyes"MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Originally Posted by Dualieare these gauges for gas only?   would they work with hyd oil?
Reply:Would they work as replacement gauges on a oxygen regulator ? Perhaps the 400/4000 set. If so I'd be interested in a pair. Let me know how much.Thanks Duane
Reply:Oxygen service would be fine.  Just PM me a ship-to name and address.  If only one set is needed, I'm pretty sure they'll package up nicely in a USPS Small Flat Rate Box for $4.95.That's it, just what ever it cost to get them to you.  These are new take-offs and were otherwise destined for the dumpster.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:socoj2 and Showdog75,PMs sent.  You should see your gauges Moday/Tuesday.  Both sent out USPS Small Flat Rate Box on Thursday.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Got mine today thank you.
Reply:Wow!  Never would have expected that from Snail Mail.I assume they arrived intact?  I was a little concerned as they were pretty tight in that SFRB.  Couldn't get as much bubble wrap around them as I would have liked to.edit:  Forgot to say thanks for the payment!Last edited by duaneb55; 05-08-2010 at 11:19 PM.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Hey Duane, I got them. didnt realize you are in Orange. I grew up in lake Charles a i ahve family in Port Arthur and Houston. Ill be through there next year!
Reply:Originally Posted by socoj2Hey Duane, I got them. didnt realize you are in Orange. I grew up in lake Charles a i ahve family in Port Arthur and Houston. Ill be through there next year!
Reply:PM sent"Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Got everyone's PMs so far but as a reminder, there are two pressure range sets.  4000/400psi and 6000/600psi so it you haven't told me which one(s) you need/want, I'll need to know before I can send them out.That said, I'm going to be out of town for the next few days so I won't be able to send those I know about out until I get back.  When I get a total count of both ranges requested I'll post what I have left.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Still won't be home until later tomorrow but in adding up all the requests that have confirmed what pressure range set(s) are desired, I may be tapped out on the 4000/400psi units for the time being.Just so you know.DuaneMM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:If I've done the math right, all available gauges are accounted for with some 'second choice' requests being accommodated and only one that will have to wait until the next batch.I'll post when I have more.DuaneLast edited by duaneb55; 05-15-2010 at 10:57 AM.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2025-12-31 08:09 , Processed in 0.099340 second(s), 18 queries .
