Not really a project. Yet.
发表于 2021-8-31 22:33:37 | 显示全部楼层 |阅读模式
Came up with this random idea, just throwing it out there to see if it has already been thought of, or if it's even possible. My dry cut saw throws chips everywhere when cutting (still beats sparks and dust).  Probably 90% of them fly out the back of the saw and some on an angle out the back of the saw.  I was trying to figure out a way to make some sort of shroud, out of sheet metal maybe 14ga-ish and magnetize it.  Sort of like a mag drill base.   It would theoretically catch most of the chips and then with it being an electromagnet, have the ability to be switched off and just wiped clean.  Any thoughts? Feasible? Or have I gone off the deep end?
Reply:sounds like a lot more work than is needed when safety glasses and a face shield will do the job.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Quite a few people just build a deflector which directs the chips into a pile.  This can be integrated into a stand.
Reply:Why would it have to be an electro-magnet? You could just stick a powerful magnet to the back side, and pull it off when you want to dump the chips.Just build a deflector sheild, like kazlx said and stick your magnet to it. When you get enough chips gathered up, weld them together into some kind of art project.
Reply:I built a stand for a welding blanket that keeps the shavings more localized so it's not such a pain to clean up. Sent from my iPhone using TapatalkMiller Bobcat 250Syncrowave  200Millermatic 252Spoolmatic 30ASpectrum 625 X-TremeMaxstar 150SVictor O/A torchesDewalt angle grindersWelded on/off for over 40 years.
Reply:It didn't even cross my mind to just stick a regular magnet to it lol I might give that a shot.  The chips are just such a pain in the ***. Especially in a home garage setup. I know safety glasses and a face shield would suffice, I wear safety glasses anyway, just trying to contain the chips as much as possible
GMT+8, 2025-12-31 16:57 , Processed in 0.071388 second(s), 18 queries .
