Question about rough texture.
发表于 2021-8-31 22:33:35 | 显示全部楼层 |阅读模式
Might be a dumb question, but how do you achieve the rough texture on metal that you sometimes see, especially on gym equipment? I was asked to build some small stuff for a local gym I workout at and was wondering if there is any way to achieve this.
Reply:Most of that equipment is powdercoated.  If the surface is rough its probably a hammertone powdercoat.
Reply:Hammerite is a product that's readily available and easy to use.  Here's a discussion about other methods http://www.finishing.com/0400-0599/409.shtmlEverett
Reply:jkolbAre you asking about the texture on the: weights, the mainframe, or the grips?Opus
Reply:Wrinkle black powdercoat
GMT+8, 2025-12-31 13:32 , Processed in 0.106576 second(s), 18 queries .
