Old SA-200 Update
发表于 2021-8-31 22:33:30 | 显示全部楼层 |阅读模式
Hi Everyone,I just spent the day doing some preliminary work and testing on the the oldest of the three SA-200s I bought to restore and sell.  I have to say that given the condition and state of dis-repair, I was impressed.  The thing is missing a starter so I back fed the generator with another DC welder to run it as a starter motor.  I was able to get it fire up on starting fluid but the carb was so full of crap it wouldn't give fuel to the engine.  So, I removed the carb and took it to my bench.  I got it apart and found it was full of crap.  I cleaned everything  with acetone, made a new gasket and put it all back together.  I fed it with a seperate fuel source because the tank is just as bad as the carb was.  BTW, if you can make a gasket you don't need the kit.  Save your money...  I put the carb back on and fired that baby up.  She choked and sputtered for a few minutes and then smoothed right out.  The idler needs a little work and adjustment but otherwise it ran great.  I decided to see how it would weld.  I laid down a few beads and it was smoothe.  This is one of the old round generators with the copper windings.  I intend to restore it nicely with some new features such as a new one wire self contained alternator, one of the new starters, and a full set of gauges.  I was really impressed by how good the machine welded considering the fact that the brushes are hardly touching the commutator.  I will od course take care of all that.  Now, if I can just get that guy that has the starters to answer my PM to him.  I'm ready to buy.  I am also looking for a source for new doors and a hood.  I might as well go ultra delx on this one as it will be the most valuable.Dave B.E-MAIL:  [email protected] PAGES:  www.wfmservice.comwww.rides4rides.comwww.pvpmedia.com/53f100.htmDad always said, "If it ain't broke, don't fix it."I say, We can make it better.
GMT+8, 2025-12-31 16:56 , Processed in 0.401409 second(s), 18 queries .
