remote cord specs...
发表于 2021-8-31 22:33:28 | 显示全部楼层 |阅读模式
Can anyone tell me what the gauge of the remote cord for a miller 12RCalso how many wires are used?my guess is 8 wiresthanksG
Reply:8 conductor with the Sense Lead option and 6 without.  16ga. is typical, 14ga. will get you several hundred feet capability.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:thanks duaneb55.is that 200'? or more? with the 14 gaG
Reply:In actually running the numbers, "several hundred feet" for 14ga. would be an incorrect claim.  My apologies.With 14ga., 200' would result in a supply voltage loss in the upper acceptable limit range so I would draw the line there if it were mine.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:thanks againG
GMT+8, 2025-12-31 15:10 , Processed in 0.097015 second(s), 18 queries .
