Need to straighten this…
发表于 2021-8-31 22:33:24 | 显示全部楼层 |阅读模式
Morning,Have a Deere 450 that had the tabs for the drawbar (on the rear crossmember) damaged- one had been cut off and the other bent.Piece is 5/8" thick and 3" wide. I put a bottle jack on it and it started turning the crossmember.So, I need to put some heat on it. My little o/a cutting torch setup can't get enough heat in to it.I'm wondering if my torch will handle a rosebud.What size rosebud tip is recommended and I can see if my torch will accommodate it.Or, would a carbon in standard electrode holder work to heat?I have a DialArc 250 AC/DC but don't want to burn it up.Last option, as I need to build one replacement tab, is just torch it off and make two.Thanks for any help,DB
Reply:It will likely be faster to just cut it off and weld two new ones on - that's what I would do anyway.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Originally Posted by MinnesotaDaveIt will likely be faster to just cut it off and weld two new ones on - that's what I would do anyway.
Reply:Thanks, guys.That's kinda the way I'm leaning.Precious owner wasn't sharpest or best with maintenance…Off it comes!!Have a great 4th!!DB
Reply:Is that were a drawbar should be mounted? It seems to me there should be a bolt drawbar on crawler because there is a heck of lot more weight and pull than a rubber tired tractor. I think a 450 JD has about  16,000lbs. drawbar pull or approx. it's weight if I recall.
GMT+8, 2025-12-31 16:57 , Processed in 0.094359 second(s), 18 queries .
