1971 lincoln weldanpower ac130 weak welding arc
发表于 2021-8-31 22:33:24 | 显示全部楼层 |阅读模式
i just picked up a 1971 weldanpower ac130 for $100 yesterday and was told it needed some carb work. so i got a rebuild kit, new spark plug, cleaned and adjusted the point and it fired on the first pull!! it runs great but im having a really weak welding arc. the only rods i have with me are 3/32 6011. i have to crank the machine all the way up for it to barley even run a bead. ive read about cleaning or replacing the brushes but not to sure where they are or what they look like. this is my first welder generator. also the outlets run a circular saw just fine. any suggested would be greatly appreciated, thankjs in advance
Reply:What's its 4-digit Code# off the faceplate?Are you sure the engine is running at the proper high idle no-load speed of 3700rpm?If not, go to Home Depot, Lowes, Harbor Freight, etc. and get one of these:Set the machine selector for Auxiliary Power output, place the throttle in the high idle (WELD/POWER) position, plug the Kill-a-Watt it into the auxiliary power outlet, select the Hz readout and set the engine no-load speed to register between 61 and 62.5Hz on the display which equates to 3650-3750rpm.Last edited by duaneb55; 07-01-2015 at 01:42 PM.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Originally Posted by duaneb55What's its 4-digit Code# off the faceplate?Are you sure the engine is running at the proper high idle no-load speed of 3700rpm?If not, go to Home Depot, Lowes, Harbor Freight, etc. and get one of these:Set the machine selector for Auxiliary Power output, place the throttle in the high idle (WELD/POWER) position, plug the Kill-a-Watt it into the auxiliary power outlet, select the Hz readout and set the engine no-load speed to register between 61 and 62.5Hz on the display which equates to 3650-3750rpm.
Reply:Understood on the present outlet voltage but it could be in excess of 125V no-load at the proper Hz which is a true indicator of operating rpm rather than voltage.The Kill-A-Watt runs less than $20 and I recommend using one to set any generator engine speed and to monitor frequency/voltage in the house when using a back-up generator.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:I agree with Duane 100 percent!But may I also offer to suggest to look at the lead connections before assuming its the Brushes? Reason being on mine the connections on my stinger get "crusty" hence exhibiting an issue similar to what you are describing!
Reply:alright duaneb55 and anybody else that can help me out(much appreciated in advance), i plugged in the hz meter and got around 65hz. so i turned the engine down to 62hz. still same problem. all i get is a spark at 130amps using 3/32 6011. is this a capacitor issue then? if so i understand lincoln doesnt make the 200 uf capacitor anymore and i would need to get a 800uf one. do i have to get this from lincoln or are there other options?
Reply:Are you able to at least strike/maintain an arc at any of the other settings?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:i could get a 1/16 6011 to run too small beads but was very hard to do. all the settings seem to be putting out the same amount of amps. on the faceplate there is a stud sticking out that says grounding stud. there is nothing connected to it, what is this used for?
Reply:Originally Posted by cmlepineon the faceplate there is a stud sticking out that says grounding stud. there is nothing connected to it, what is this used for?
Reply:I bought my capacitors on Ebay, I think there was four 200 UF capacitors in there?I would still check for corrosion on connections first.
GMT+8, 2025-12-31 16:56 , Processed in 0.322576 second(s), 18 queries .
