What's is worth??
发表于 2021-8-31 22:33:24 | 显示全部楼层 |阅读模式
I'm looking at an sa 200 but am not sure how much it's worth and the guy is asking for an offer as he isn't sure either. Any info would be helpful. Thank youSent from my iPhone using Tapatalk
Reply:That thing looks like it was rode hard, & put away wet.All the typical questions come into play here...does it run, how many hours on it, how's the oil look, did you try to weld with it, try all the settings, etc.?Rich
Reply:Yea it welds fine not sure on the hours I will find out tho and the settings work he did say he thinks the spark plugs may be stuck and take some work removingSent from my iPhone using Tapatalk
Reply:How much are you willing to pay for it?Rich
Reply:Is 2-3000 to much?Sent from my iPhone using Tapatalk
Reply:It is worth exactly what the buyer and seller are both happy with.
Reply:At that time! John Sent from my XT1254 using Tapatalk
Reply:Better give a general area where you are located too. That also could have a lot of bearing on the price. Do the the leads and tanks and trailer all come with it?SA-250 TMDSquarewave 200Thunderbolt AC/DC1951 G.E. welder
Reply:Yea the leads and trailer do come with it the torch rig does not. I am located in central Louisiana Sent from my iPhone using Tapatalk
Reply:I would guess around $1200-1800 maybe. It all depends on where you look and who you are buying from. Go to a big auction with people expecting newer stuff and it might go for $800-1200. If you look on CL people around might be asking $4k. If it was in OK or TX looks like it would be a little higher. Just a guess and an opinion.SA-250 TMDSquarewave 200Thunderbolt AC/DC1951 G.E. welder
Reply:Alrite thank you for the infoSent from my iPhone using Tapatalk
Reply:Do not take that as gospel. Look around on CL some in your area. If you are looking to keep this thing from now on and really want it, you probably would be all right with $2k. I sure do not think I would want to go much higher than that. Good luck with it.SA-250 TMDSquarewave 200Thunderbolt AC/DC1951 G.E. welder
Reply:Thank you!Sent from my iPhone using Tapatalk
GMT+8, 2025-12-31 15:11 , Processed in 0.097961 second(s), 18 queries .
