Thermal Pak 3xr won't fire up
发表于 2021-8-31 22:33:24 | 显示全部楼层 |阅读模式
Hello everyone, this is my first post so please look over any mistakes I make. Now to get to the point, a friend of mine brought me over a Thermal Pak 3xr plasma cutter that wasn't working. You could turn it on and the first two lights would lite up you could set the air (I set it to 65lbs.) but when I set it to run and tried to use it did not work. I opened it up and after a few minutes found what looked like a bad relay for the HF, so ordered and installed a new one. After installing the new HF relay and retrying the cutter it would arc but would not start the cutting cycle, any idea's on where to look next. ThanksRunout57
Reply:Hello Guys, now idea's, I realize this is a tough one. I will call a tech tomorrow. Still open to any suggestions.Thanks,runout57
GMT+8, 2025-12-31 15:11 , Processed in 0.085442 second(s), 18 queries .
