Do you guys get 336 +* argon tanks with this much pressure?
发表于 2021-8-31 22:33:22 | 显示全部楼层 |阅读模式
A guy from matheson told me once ur not allowed to fill tanks past 2500 psi for argon. My last bottle was 2600 psi. My gauge is a smith I think it retails for 170$. How much pressure you guys get?
Reply:Gauge reads 2800psi^^^
Reply:Hello motolife313, you can end up with a lot of different pressure readings when you hook up your gauge and for many different reasons. For starters, bottles will have different max pressure ratings from the time that they are manufactured. Some will have a higher "over-pressure" rating and this is indicated by how they are stamped. Others know the listing of how this is indicated, I'm sorry I do not, likely they'll chime in here. Another thing to consider is ambient temperature at time of filling. If your bottle has been filled when it is cool out and then set at the dock and you pick it up some time later when the temperature has increased it will read a bit high, if you pick it up when it is colder than when it was filled it will read a bit lower, very common to run into this. I am sure that others will have additional information and with more specifics, but still, all in all you do not have to worry about the 2800 psi that shows up on your gauge. One other possibility is that your gauge is out of calibration and reads a higher pressure than is actually present. I know that you said that it is a high-dollar gauge yet  they can have issues too. Good luck and best regards, Allanaevald
Reply:The tank is stamped with a "+" sign after the pressure rating. It is allowed to receive up to 10% overfill if designated.
Reply:The cylinders get hot when filling but 2500 PSI max doesn't make sense considering you can get 4500 PSI cylinders with argon. You have to monitor cylinder temperature when filling so they don't get too hot. There not so hot you can't put your hand on them but you can feel the heat. The place I used to work, I think they filled standard cylinders to 28?? PSI hot and there was a chart that converted the hot pressure to what it would be at room temperature. I think 2640 PSI is a common cylinder pressure rating but if you got a 2500 PSI you'd be doing pretty good. A 2800 PSI cylinder, don't complain, you got a bonus.Last edited by Welder Dave; 06-30-2015 at 01:28 AM.
Reply:Originally Posted by Welder DaveI think 2640 PSI is a common cylinder pressure rating
Reply:I think altitude has an effect on pressure.
Reply:Originally Posted by InsanerideI think altitude has an effect on pressure.
Reply:Originally Posted by Welder DaveThe cylinders get hot when filling but 2500 PSI max doesn't make sense considering you can get 4500 PSI cylinders with argon. You have to monitor cylinder temperature when filling so they don't get too hot. There not so hot you can't put your hand on them but you can feel the heat. The place I used to work, I think they filled standard cylinders to 28?? PSI hot and there was a chart that converted the hot pressure to what it would be at room temperature. I think 2640 PSI is a common cylinder pressure rating but if you got a 2500 PSI you'd be doing pretty good. A 2800 PSI cylinder, don't complain, you got a bonus.
Reply:Originally Posted by GravelI've never seen one filled to 4500 psi or anything close to it. What kind of cylinder is this?
Reply:There are even some cylinders that go to 6000 PSI. I think the 4500 PSI cylinders are chrome-moly to handle the extra pressure. They use a CGA 590 fitting instead of the CGA 580. Mostly used for mix gasses for MIG and dual shield.
Reply:Mine was 2800!! Blew my reg (old and failing) out. I thought it was over psi or dude screwed me. Ive heard that trico wont go beyond 1000 and anything over 800 is considerd full. Ive bought several from airgas and they were always 1500-1800psi.esab 260 multimasternew tech 150 invertorlincoln 140 cheapo
Reply:4500 PSI in the US are CGA 680.
Reply:My E2 bottle(only had 3 exchanges so far)are above 3000psi when full, that with BOC gases here in OZ
Reply:Set them in the desert sun and you can see high 3000'sSent from my SCH-I545 using TapatalkCRIME SCENES, COURT DATES, FUNERALS, RIDING THROUGH THE CITY WITH A BITCH THAT IS JUST BEAUTIFUL IT'S JUST BUSINESS AS USUAL.
Reply:Mine reads 2600 psi when full.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
GMT+8, 2025-12-31 14:04 , Processed in 0.069731 second(s), 18 queries .
