7 Mills & 2 Iron workers
发表于 2021-8-31 22:33:20 | 显示全部楼层 |阅读模式
Chattanooga TN Craigslist:55 ton Edwards iron worker $2000 single phase 220 volts , 90 ton edwards iron worker $2500 3 phase Radial drill with drills taps and clamps $2000 7 milling machines 4 late model 2 with tooling and clamps starting at $800 to $4000 can be seen in downtown chattanooga Call after 3:00 PM http://chattanooga.craigslist.org/tls/1712031816.htmlLooks like a reasonable deal for somebody.Burt _____________________Miller Syncrowave 250Millermatic 211Miller 375 Plasma Cutter Hobart Handler 12010FtDrillBit.com
Reply:Are either of the iron workers still available?John
Reply:You will have to contact them. Don't know.Listing shows one sold, so I suppose other is available.Burt _____________________Miller Syncrowave 250Millermatic 211Miller 375 Plasma Cutter Hobart Handler 12010FtDrillBit.com
GMT+8, 2025-12-31 13:49 , Processed in 0.074444 second(s), 18 queries .
