f.s. Stelron and PDC rotary index tables
发表于 2021-8-31 22:33:19 | 显示全部楼层 |阅读模式
I have one of each.The Stelron unit has a gear reducer built in with a dc motor. Can be programmed for automation purposes. This is in working condition. New, these cost several thousand dollars. I also have a PDC index table that is brand new and still in the crate. I believe this one was just north of $3000 last year when purchased. I got these at an auction and now they are in the way. I had another unit listed on ebay and sold it, but these are in the way and I do not like dealing with ebay.I will sell both of these for $600. They are heavy (~150-200 lbs each). You could turn around and make a killing on these if you wanted to take the time on fleabay.I would be willing to drive within reason to meet you if you wanted.I am near St. Louis, MO.Grant Attached Imageshttp://jackalopefab.com/MM210Synchrowave 200DXMiller XMT350 w/60series feederMiller Bobcat 250 with SGA 100 and spoolgunHTP PlasmaFull Machine shop with everything
Reply:First pic is the one I sold and I cannot remove it from the post. The Stelron unit is similar to the first pic only larger and and much more capacity. It had a 36" diameter plate on top that was 1" thick. Extreme amount of torque and precision.Granthttp://jackalopefab.com/MM210Synchrowave 200DXMiller XMT350 w/60series feederMiller Bobcat 250 with SGA 100 and spoolgunHTP PlasmaFull Machine shop with everything
Reply:I'm interested in the PDC index table you have for sale.  Please contact me with details via email.  Please provide model number and method of payment.Regards,Willis UsherSonocoHartsville, SC
Reply:Willis,  All the indexing tables were sold some time back. Granthttp://jackalopefab.com/MM210Synchrowave 200DXMiller XMT350 w/60series feederMiller Bobcat 250 with SGA 100 and spoolgunHTP PlasmaFull Machine shop with everything
GMT+8, 2025-12-31 14:10 , Processed in 0.149328 second(s), 18 queries .
