TIG torch to cure powder coat?
发表于 2021-8-31 22:33:14 | 显示全部楼层 |阅读模式
I make welded sculpture far too large to put in a powder coat oven, but I would like to get a little bit of powder coating color here and there.  I wonder if anyone has tried or has any thoughts about using a TIG torch to heat the metal from the backside, around the edges or whatever. I can certainly see some problems with this, but it doesn't mean they can't be solved by a bunch of smart guys. Thanks Larry
Reply:Why not use a good paint?Airco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power) Hobart MIG
Reply:Krylon came out with a new paint. It's called "Dual". It combines both primer and paint in the same can. It has the appearance of powder coat but is not as durable, of course. I've done lots of powder coat in my homemade 2' X 3' X 6' powder coat oven. As you may know, it takes at least 350 to 375 deg. F. for about 15 minutes to cure. Instead of a TIG torch, you could use a heat lamp for 15-20 minutes to get the powder to cure. People do this when they  don't have a suitable oven or just want to do or re-do a spot.Miller Millermatic 252Miller Syncrowave 200Liincoln AC-DC 225Victor O-A Set
Reply:I think a propane torch would be better then tigTim Beeker.
Reply:Caswell plating has these mobile curing lamps.  The small ones aren't too expensive and would probably do a better job.  I think trying to sustain a temperature with tig torch is going to prove problematic.http://www.caswellplating.com/powder...ing-lamps.htmlThermal Arc Fabricator 281Miller 350PMiller Syncrowave 200Lincoln ProCut-55Jackson NexGen
Reply:I think you're right. Either a propane torch or a radiant heater would work better. I have a couple of 1500 W radiant heaters that would probably do the job. Thanks for the guidance.Larry
GMT+8, 2025-12-31 14:04 , Processed in 0.101182 second(s), 18 queries .
