esab 9000 b3
发表于 2021-8-31 22:33:14 | 显示全部楼层 |阅读模式
how does it weld? there is an auction locally that has close to a pallet of it. I have never used esab products before. right now Im using a hobart dual shield wire xl arc 71 i believe. I only weld shop type stuff so I didn't know if it would mess me up welding with the harder wire thanks for any advice. it should go cheap, and  it would be nice to not be paying 4.00 per lbs for wire.  there is also some 70 ultra T but I don't know wires very well.Do not argue with an idiot. He will drag you down to his level and beat you with experience.
Reply:I didn't get any of the 9000 b3 it went for 80.00 per roll but I did get 140 lbs of 308 stainless rod for 25.00 per 10 lbs can and 650 lbs of 6010 +p for 50.00 per 50 lbs canDo not argue with an idiot. He will drag you down to his level and beat you with experience.
GMT+8, 2025-12-31 13:57 , Processed in 0.098421 second(s), 18 queries .
