7018 on pipe uphill
发表于 2021-8-31 22:33:09 | 显示全部楼层 |阅读模式
Did this today at my college first time going uphill 7018 on pipe ever, what yall think? Wasnt a burn through or anything but any tips or advice is greatly appreciated thanks!Last edited by Justin Ray Wert; 04-10-2014 at 12:18 AM.
Reply:Nice shot of the pipe.  Is there a wild there?  A little closer would help.Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:Yes there is a weld there ha here's a closer pic
Reply:Looks great!!!What rod, and amperage???More importantly, what machine you using??~JohnJust a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:And anotherSent from my XT907 using Tapatalk
Reply:I was using a Lincoln 305 ranger and running 90-93 ampsSent from my XT907 using Tapatalk
Reply:What size pipe?  What settings?  Position? Looks like a good start. Looks like you have a couple high spots on the side. Less time on center will keep it from sagging. I'd say do it another hundred times for practice and confidence Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:Yeah I was covering a weave bead someone tried putting all the way around it, looked that way all the way around I usually weld pipe downhill with 7010 p1 Sent from my XT907 using TapatalkLast edited by Justin Ray Wert; 04-10-2014 at 01:40 AM.
Reply:It was gouged out and ugly so I cleaned it up and put caps on it filled where it was gouged and eventually made it look like thisSent from my XT907 using Tapatalk
Reply:It looks a bit undercut on the socket side but the beads look nice and consistent.
Reply:Originally Posted by Arizona SA200It looks a bit undercut on the socket side but the beads look nice and consistent.
Reply:Its lookin good.
Reply:Originally Posted by Arizona SA200Its lookin good.
Reply:7018 uphill is very enjoyable.... If you stay in control.Keep practicing, feel free to post up more pics, or ask more questions.We all started where you are.Good Luck,~JohnJust a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:I posted some pics up on my own thread. Not my greatest work but still some of the crap i have had to do.
Reply:Looks a little under cut but not to bad for a first go at it. Not sure what your procedure is but we are required to stack the beads from the pipe. Up on the socket not from the socket or the larger diameter down
Reply:Yeah I would of done that but I had to cover bad undercut and a sloppy weave bead and some other stuff that was under itSent from my XT907 using Tapatalk
Reply:Looks good !! But I have to ask what's with all the partial rods in the bucket?                                                    MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:Originally Posted by mla2ofusLooks good !! But I have to ask what's with all the partial rods in the bucket?                                                    Mike
GMT+8, 2025-12-31 14:04 , Processed in 0.065021 second(s), 18 queries .
