Migpak 10 prob
发表于 2021-8-31 22:33:06 | 显示全部楼层 |阅读模式
hey,  i have a migpak 10, and when i plug it in,it sounds like a solenoid clicks on and it hums quietly, and when i turn on the actual power then open the argon, the gas starts freely flowing without even pushing the trigger...this problem just started this evening after i turned it off and let it sit for an hour then came back to weld. any suggestions???thanks MATTp.s. don't mind the spelling and grammer, english is my second language
Reply:Sounds like the Gun trigger is stuck. Try disconnecting the leads in the wire chamber and see if that fixes things. If it does - then take a look in your gun. If it doesn't - then it is internal to the machine.
Reply:Thanks Big_Eddy! that seemed to have stopped the problem, i will look into picking up a new gun this weekend!i wish i would have tried that myself before posting on the siteMATT
GMT+8, 2025-12-31 05:42 , Processed in 0.100072 second(s), 18 queries .
