Aluminum Squirt Gun???
发表于 2021-8-31 22:33:04 | 显示全部楼层 |阅读模式
I have lots of aluminum, 0.90 and 0.125, sheet metal work. Currently I'm tigging but need to switch to mig for cost effectiveness. I have a MM 252. Any advice as to which spool gun would perform the best. Thanks!Miller TrailBlazer 251Miller HF-250-1Miller MaxStar 150 STLHyperTherm PowerMax 380 plasmaLincoln PowerMig 180Millermatic 252Miller Diversion 180
Reply:You can't beat a 30A and it's plug and play on your 252.My name's not Jim....
Reply:15A or 30A would both work well. The .090 ( I assume you ment this since .9 (between 15/16" and 7/8")  is not what I'd call "sheetmetal") will be a fun treat to work with if you haven't done this before..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:i have nothing bad to say about my 30a.MM 251MM 135Lincoln Pro cut 55Bobcat 250Miller Thunderbolt ac/dcolder ac forneyJackson nexgen 3n13-Smith OP setups97 Dodge dieselMakita chopsawJet swivel head bandsawlincoln tig 300/30030a spoolgunpuma port. gas air comp.
Reply:Hey wagin,Get the spoolgun & don't let cost affect your decision. You will find a marked improvement with production &, believe me, that SG will pay itself off in no time flat. If the 30A is already setup for the 252, get it & start runnin'.........DennyComplete Welding/Machine/Fab. ShopMobile UnitFinally retired*Moderator*"A man's word is his honor...without honor there is nothing.""Words are like bullets.... Once they leave your muzzle, you cannot get them back."
Reply:i recently did a bunch of research and found that the 30A seems to be the best out there  got one on ebay new for 775 and had an adapter made to run it on my lincoln power mig255 seems like a great gun havent got to use it a bunch yet also i know that miller often has some reconditioned units at good savings350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:Nobody is recommending a push-pull gun instead of a spoolgun?Those little 1 lb spools of aluminum are kind of pricey on a $/lb basis.  Hmmm, a quick check at weldingdepot shows the little 4" 1 lb aluminum spools at about $5-$6 depending on the wire diameter and the alloy and the big-boy 12" 20 lb spools at about $4.xx/lb again depending on wire diameter and alloy.  Those 5 lb 8 inch spools are running around $8-$10/lb though!  Ouch!Go big or go home, eh?Miller XR push-pull, listed as compatibile with the MM252.A Miller article about welding aluminum with the XR push-pull.  They happen to mention welding 0.090 aluminum as well.  http://www.millerwelds.com/resources...Oshkosh-Truck/  The best laid schemes ... Gang oft agley ...
Reply:Wagin,The 30A is "the only" way to go as far as a "spoolgun" on the MM252.Welding .090 aluminum, though, is not it's fortay.  Gonna be tough without pulse.If you've got "a lot" of this type work, you may want to explore moving up to the MM 350P.Syncro 250 DX Dynasty 200 DXMM 251 w/30A SG XMT 304 w/714 Feeder & Optima PulserHH187Dialarc 250 AC/DCHypertherm PM 1250Smith, Harris, Victor O/ASmith and Thermco Gas MixersAccess to a full fab shop with CNC Plasma, Water Jet, etc.
Reply:from what ive read the 30a can be used as push pull aswell it all depends what you want the nice thing about the spoolgun is i can grab one or the other without changing reels etc the lil rolls are more compared to a big spool guess it all depends what kinda setup you wanna run350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
GMT+8, 2025-12-31 05:35 , Processed in 0.153721 second(s), 18 queries .
