Milwaukee welding magnets
发表于 2021-8-31 22:33:03 | 显示全部楼层 |阅读模式
Has anyone seen the new lineup of Milwaukee welding magnets and fixtures?  I was in my local tool shop yesterday and the bloke behind the counter showed me a pic of the new lineup of magnets and fixtures from Milwaukee.I also notice they seem to be getting into the electronic stuff as well, like multimeters, laser temp guns, current detectors and stuff.Rumor is that they poached some Fluke engineers to design and build for Milwaukee.  Aparently they are as good if not better than Fluke.  Made to give Fuke a challenge in the market.Has anyone seen or used this stuff first hand?  Opinion?
Reply:maybe its some stuff there gonna test in certain markets couldn't find anything on there site350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:Could not find anything on the net as well.  Thought you may already have them on your side of the pond, but if their not in the online cataloge, then i suppose they are not officialy out yet.But i did see them in a new Milwaukee cataloge that i ws not able to take home.Now that i think of it, i should have got a pic with my phone.
Reply:Last year I bought the following:http://www.milwaukeetool.com/tools/t...-meter/2235-20Heavy duty True-RMS electrical current tester for professional residential, commercial, and industrial applications. The perfect tool for the professional electrician; includes all the features that are needed to get the job done in the field, on-site or in the plant. Milwaukee 2235-20 Clamp Meter features: jaw size of 1.0” measuring up to 350 MCM cable; rated CAT III 600V; current measurement to 400 amps AC; voltage measurement to 600 volts AC/DC; LED Work Light to improve task lighting; resistance measurement to 4000 ohms; test for continuity; black on white display and backlight for easier reading; rugged over-molding for increased durability and user grip; includes one (1) electrical test lead set, two (2) AAA batteries, and manual; covered by 5 year warranty. Nothing but HEAVY DUTY.Features    * Measures up to 400 amps AC, Large 1.0” jaw opening    * Thin Jaw Profile for easier wire measurement in panels or in bundles    * Wide Voltage range to 600 AC/DC volts    * True-RMS for accurate measurement in all applications    * Built-In LED Work Light    * CAT III 600V for increased safety    * Black on White Display with Backlight for easier reading    * Rugged over-molding increases durability and user grip------------------------------------------------------------------------------------------------------------------------------------http://www.milwaukeetool.com/tools/t...imeter/2216-20Heavy duty True-RMS meter for professional residential, commercial and industrial applications. The perfect tool for the professional commercial or industrial electrician; includes the features that are needed to get the job done in the field, on-site or in the plant. Milwaukee 2216-20 Digital Multimeter features: True RMS measurement to accurately measure all applications; CATIII 600V for increased safety in demanding electrical environments; AC voltage range of 6 millivolts to 600 volts; DC voltage range of 600 millivolts to 600 volts DC; Resistance measurement from 600 ohms to 40 Mohm; frequency measurement from 10Hz to 50 kilohertz; detects continuity at less than 30 ohms; Current measurement to 10amps AC/DC; hold function, min/max function and digital bar graph readout; black on white display and backlight for easier reading; rugged over-molding for improved durability and user grip; proprietary rail system for mounting accessories; includes one (1) test lead set, two (2) AA batteries, and manual; covered by 5 year warranty. Nothing but HEAVY DUTY.Features    * True-RMS for accurate measurement in all applications    * Wide Voltage range to 600 AC /DC volts    * Resistance range from 600 ohm to 40 Mohm    * Auto Range to mV    * Frequency measurements from 10Hz to 50kHz    * Current Measurement to 10A AC/DC    * Rugged over-molding increases durability and user grip    * CAT III 600V for increased safety    * Capacitance to 1000 μF--------------------------------------------------------------------------------------------------------------------http://www.milwaukeetool.com/tools/t...-meter/2205-20The Milwaukee Fork Meter is a heavy duty True-RMS electrical tester for professional residential, commercial and industrial applications. The 2205-20 is four tools in one providing current measurement, voltage measurement, voltage detection and task lighting. In addition, the new tool provides a wide 0.63” fork opening, high 200amp current range and a high contrast white-on-black display. Covered by Milwaukee 5-Year Warranty.Features    * Measures up to 200 amps, Wide 0.63” jaw opening    * Wide Voltage range to 1000 volts AC /DC    * True-RMS for accurate measurement in all applications    * Lo-Z measurement to eliminate ghost voltage    * Built-In Voltage Detector and LED Work Light    * High Contrast, White on Black Display with Backlight for easy reading    * Rugged over-molding increases durability and user grip    * CAT IV 600V / CAT III 1000V for greater safetyM12 versions too.I like the displays much better than anything I have use before.  I still do use a Simpson old school type, also.
GMT+8, 2025-12-31 05:24 , Processed in 0.119129 second(s), 18 queries .
