Portaband saw blades...What TPI?
发表于 2021-8-31 22:33:03 | 显示全部楼层 |阅读模式
Just like that title says what TPI should I be getting?  I only cut mild steel.
Reply:Depends on the thickness & type of the material you are cutting.  Most literature I've seen recommends 2-3 engaged teeth at any given time on tubing.I am partial to the dewalt HD blades because they are thicker than the milwaukee blades and at least on my saw, cut considerably straighter.
Reply:Originally Posted by greenbuggyDepends on the thickness & type of the material you are cutting.  Most literature I've seen recommends 2-3 engaged teeth at any given time on tubing.
Reply:So a higher tooth count for exhaust tubing and less for say 1/2" plate.
Reply:Exactly....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:thanks zap!
GMT+8, 2025-12-31 05:24 , Processed in 0.098850 second(s), 18 queries .
