http://richmond.craigslist.org/tls/1815489202.html
Reply:That is funny. Guess he didn't know about V x A = W, or he would have known there were not enough watts to allow 250 amps genny output at 240 volts, about 40KW short of power for that.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:I just thought that was A lot of cash to throw at something you didnt even know what it was "big black cords".
Reply:Originally Posted by jreynoldsweldingI just thought that was A lot of cash to throw at something you didnt even know what it was "big black cords".
Reply:Never mind the trailblazer will run the fridge and lights just dandy, really only need the critical stuff on backup. Guys want prime power during an outage but forget that means they'll burn a whole LOT more fuel
Reply:Originally Posted by forhireNever mind the trailblazer will run the fridge and lights just dandy, really only need the critical stuff on backup. Guys want prime power during an outage but forget that means they'll burn a whole LOT more fuel
Reply:If he has propane on his property, a propane generator would make alot of sense.Funny thing is, he didn't need all the welding stuff and could easily have bought a brand new Bobcat for less money than he paid for the used machine with the accessories he had no use for...I got a kick out of the 'big black cords' comment too! MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Originally Posted by jreynoldsweldingYea I know, and LP. Where are you going to find a lot of that in a power outage? I dont get people! At least he should have bought a gas machine, diesel if he knew better! Funny stuff.
Reply:Originally Posted by jwormanActually, I think getting a LP rig is the best thing he did. You buy the LP BEFORE the outage! LP stores for a very long time! 10 years and more is not problem. Gasoline and diesel turns to gunk if you don't use them in a fairly short time. Even if you treat the gasoline with staybil, it won't last for years. In addition, you don't have to worry about the carburetor gunking up from not starting it for a year or more. I have a small LP generator. I didn't start it for over 3 years. I pushed the prime button after hooking a LP cly to it, and it started on the first pull. I think my luck with gasoline would have been much different.I bought a LP bobcat not too long ago, just for the emergency aspect. I'll weld a little with it, when the opportunity comes up, but it is mostly a standby unit for the house and well. My house runs on Nat gas, but you can bet we have a few hundred gallons of LP, just in case. |
