I have a Victor Performer torch set with the edge ESS3 regulators, I use the acetylene reg with propane. http://victortechnologies.com/victor...odID=0384-2045I bought the Flange Wizard burning tools but they require the larger body torch. The torch I currently have says it will cut up to something like 6" with optional tips, don't know how true that is but mostly I'd be cutting 1" and under. The salesman said that if I wanted a larger body torch I would have to buy new outfit with bigger regs and all that other stuff. I do have quick disconnects on the reg and torch side but if I hooked up my 1/4" x 25' hose and purchased a larger body torch would the regs supply enough flow/pressure for what I cut?If not by the time I get new regs and a torch I can get this set for $419http://www.weldersupply.com/P/461/Vi...yDutyJourneymaTOO MANY TOOLS & NO MORE SPACE
Reply:Yes.The salesman is correct. What are you cutting ?Last edited by Burpee; 03-06-2014 at 08:06 AM.Bubble gumTooth pixDuct tapeBlack glueGBMF hammerScrew gun --bad battery (see above)
Reply:What tools did you buy? I was unaware of any FW tool that holds the torch body itself.
Reply:I don't see why you would need high-capacity regulators."USMCPOP" First-born son: KIA Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Originally Posted by walkerWhat tools did you buy? I was unaware of any FW tool that holds the torch body itself.
Reply:Originally Posted by OldendumI don't see why you would need high-capacity regulators.
Reply:I'm with Walker......I don't see anything on their site that grips the torch body.Your set should work just fine.
Reply:Originally Posted by vwguy3I'm with Walker......I don't see anything on their site that grips the torch body.Your set should work just fine.
Reply:Wrap some Aluminum shim stock (soda can) around the tip until it fits."USMCPOP" First-born son: KIA Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:You can absolutely use a larger torch with those regulators. The salesman's trying to make some extra profit off of you.
Reply:Those regs rock. I run the 100 as well as a 300 series and a 2600 cutter on those. No problems what so ever.Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:Originally Posted by Chris T.The attachment holds on to the tip of the torch. The med duty torches have smaller tips that do not fit the F.W. tools.
Reply:Thanks for the replies, I have a project where those guides are really going to come in handy.TOO MANY TOOLS & NO MORE SPACE
Reply:Never heard regulators too small unless you are lancing some 3 foot thick steel. |
