Torch help
发表于 2021-8-31 22:32:53 | 显示全部楼层 |阅读模式
Ok so what's the difference between flash back aerators and check valves and where should theyY be at the mixer or at the regulator
Reply:Check valves prevent the reverse flow of gases.  If a cutting torch tip gets clogged, higher pressure oxygen could force its way back into lower pressure acetylene hoses.  They stop this (in theory).Flashback arrestors prevent a flame front from traveling through them.  Should mixed (explosive) gases end up in your hoses, this would prevent a flame from traveling back up them.Personally, while people will argue both ways, my feeling is that if you actually purge your lines before use, the combination flashback arrestor / check valve provided with a Victor "FC" torch is more than sufficient protection.
Reply:Well I have a couple of smith torches that I am going to be using and a purox torch I have installed check valves but at thetorch side
GMT+8, 2025-12-31 09:08 , Processed in 0.079187 second(s), 18 queries .
