Finish and painted my new cart this weekend
发表于 2021-8-31 22:32:52 | 显示全部楼层 |阅读模式
I added a piece for the bottom of the bottle so it couldn't slide out since so many people recommended it.  I don't have any Lincoln equipment but I liked the red.  I'm pretty happy with the way it turned out.  I had started with the diamond plate sitting on top of the shelves but I didn't like it so I cut the supports out and lowered them so the plate would be recessed a little bit.  I can't wait for the paint to dry so I can get everything hooked up and put it back in the garage. Attached Images
Reply:That turned out awesome!IAMAW Local 330Airco 300 AC/DC HeliwelderAirco Dip-Pak 200 with Profax spool gunPowr-Kraft AC225Everlast PowerArc 200stBuffalo Forge No.21 drill pressSpeedglas 9100xxAirco, Oxweld, Purox, Victor torchesLincoln Ranger 8
Reply:really nice!!!Millermatic 211Dewalt 14" ChopsawDewalt 4 1/2" GrinderCraftsman
Reply:Great looking and nice paint job. A MILLER machine isn't gonna match too good.   You might want to protect that pretty floor before you start welding on it.
Reply:It looks great, but I would need something a little bigger.
Reply:NICE looking cart, just 1 minor problem...........................................................................  .........................wrong colour for me Miller 252Miller Bobcat 225Lincoln MigPak 1801959 Hyster forkliftHarris OA torch
Reply:Thanks for the comments.  I actually have a Hobart 210 mvp and Hypertherm plasma cutter so the color scheme is definately off.  I almost painted it orange or silver but i thought red would have a clean look to it.  I kind of wish i would have went with orange though LOL.
Reply:That paint is slick, almost looks powdercoated
Reply:That's a nice cart!Idealarc 250AC 225SVictor OA-older made in USA stuff.And a crap ton of other stuff.
Reply:That's one great looking cart, looks really professional. Like the color, very clean and smooth. Great job!
Reply:Darn nice cart, great color!
Reply:Sweet!Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:That came out great!!!  What a great choice in welders too.  Go Blue!
Reply:Beautiful.-AaronJet 17.5" Drill Press1942 South Bend 16x84 Lathe1980s Miller 320A / BP --- 2013 Power Mig 2562012 Jet 7x12 Horizontal BandsawVictor O/A Setup
Reply:Nice, post a pic with all yer stuff on it next!"All of this and some of that's the only way to skin the cat!"
Reply:You must be in Katy, Tx?
Reply:Originally Posted by BipestuffNice, post a pic with all yer stuff on it next!
Reply:Originally Posted by geezerbillYou must be in Katy, Tx?
Reply:looks really sharp! nice job!
Reply:Thanks for the comments.  Yes, I'm from Katy.
Reply:Originally Posted by GravelI was thinking the same thing.  Aren't you in Tomball, geezerbill?
Reply:Originally Posted by mliebsThanks for the comments.  Yes, I'm from Katy.
Reply:Very nice cart and paint job. Had just finished mine a couple weeks ago for a dual setup as well. Very clean.GalenMiller TrailBlazer 302 EFIThermal Dynamics 252i w/WeldCraft WP 9F tig torch and foot controlThermal Dynamics Pak 52Millermatic 250 w/Spoolmate 30aLincoln SA-200 gas driven welder from grandfatherBlacksmith shop
Reply:My new plasma cutter won't be here until next week so I put what I had on the cart today. Attached Images
Reply:Great looking cart AND you're getting a plasma cutter??? Green with envy!GravelThe difference between theory and practice is that in theory there is no difference.I bought the powermax 30 and 2 days later the 30xp was announced so I sold the 30 and ordered the xp.  A guy from the Cleveland TX area got a good deal on the 30 with a bunch of consumables and a few other things.  I kind of wish I would have just kept the 30 and started using it.
Reply:From what I read you would be happy with either one. I'm still looking for a torch to borrow to test the Max42 I think I fixed.GravelThe difference between theory and practice is that in theory there is no difference.
Reply:Originally Posted by geezerbillYou have embarrassed me into building a cart. I have been setting my WeldPak 155 on a folding chair.
Reply:Nice cart, but why build them so heavy. When I got a chance at work the other day I replaced my pos cart with a more light weight version that had 4 swivel casters on it. I'm not a pro welder by any means actually see what I do as the bottom of the food chain as a welder, I weld cages onto the frames of trailers for someone else up the line to put the sheetmetal to and someone has a nice enclosed trailer. I drag my cart around with me for 10hrs a day with a 30lb feeder on it plus wire too with 30feet of gas,remote, and hot line tagging along behind it. I can be welding on a small 5X8 trailer one minute and have to do a 7X20 the next, sheding every pound on a cart you have to push/drag around for 10hrs a day makes a world of difference.93 Bobcat 225GMillerMatic 135HF Tig 91811
Reply:Great looking cart.
Reply:Looking Great!!! Can you please briefly explain the uses of your cart???
Reply:Originally Posted by LogosweldproductsLooking Great!!! Can you please briefly explain the uses of your cart???
Reply:Can you discuss how you connected the larger rear wheels to your cart?  Did you use a solid axle than runs the entire width of the cart or did you weld small axles to the sides?  I'm in the process of making a cart very similar to yours but unsure of how to fit up the larger wheels.  One other option is to use large bolts instead of round stock but I've heard this option isn't ideal.
Reply:I used a solid axle that's 5/8" thick.  I cut 2 short pieces of 1" square tubing and welded the axle inside of it to get the right height for the front wheels.  I use the tubing so it extends about an 1/8" off the frame of the cart and use a washer between the wheel and the 1" tube so the wheels rotates without hitting the frame.    Originally Posted by blackwaterstoutCan you discuss how you connected the larger rear wheels to your cart?  Did you use a solid axle than runs the entire width of the cart or did you weld small axles to the sides?  I'm in the process of making a cart very similar to yours but unsure of how to fit up the larger wheels.  One other option is to use large bolts instead of round stock but I've heard this option isn't ideal.
GMT+8, 2025-12-31 07:29 , Processed in 0.100037 second(s), 18 queries .
